Trans '85 CJ7 popping out or third gear
gdwilder
Carbondale, CO, USA
1985 Jeep CJ7
My '85 CJ7 is popping out of third gear. Can it be repaired from the top? can you tell from the photo if it is a T176?
The shift knob is for a four speed and the t-176 was stock for a 85 CJ but to be sure you should look under the CJ and be sure it has not been changed. You can find the T-176 in our data base here -->> https://jeep-cj.com/community/threads/manual-cj-transmissions.43554/ or just click on the T-176 keyword.
If it is just worn shift forks they can be replaced by pulling the cover but if it is an internal problem you need to rebuild the transmission.
Shift image.
Morris 4X4 Parts link -->> https://www.morris4x4center.com/tremec-t176-and-t177-transmission-parts.html
And even it is just a shift fork, you should still drop the tranny. Just removing the tunnel cover will provide only Limited space to work to get the trans cover off and access to the parts for a quality job. On the other hand, no big issue dropping the tranny and it's a few hours on a Sat on the work bench type of rebuild effort. The T-150 3-speed and the T-176 4-speed are simple and easy to deal with. Take a good look at the transfer case too while you got the pair out and on the bench.
Not adding to the work but if you drop the trans why not drop the T case and at least fully service it?
