Steering !972 CJ5 steering assembly question
FFEH
I have a 1973 CJ5 304 t-15 Jeep with power steering. I am new to Jeeps. I am trying to put the steering shaft column back together. I bought the jeep and didn’t notice that the steering wheel was welded to the shaft. I have bought an upper shaft for a 1973 CJ. I just realized that it has the upper bearing and am looking for the lower bearing for the column/shaft. My question looking at the pictures provided I have a lower shaft that hits the hat bracket for the shock absorber. The knuckle that connected the lower and upper shafts is stripped and was hitting a header pipe. So I think I need to buy a steering knuckle that will connect upper and lower steering shafts and the lower bearing on the column? Can anyone tell me if I missing something I am not aware of? I did read a post that mentioned the body bushings could change the angle of the steering shaft. I am not there yet. I am just trying to figure out what I am missing to reconstruct it and end up with a stock steering wheel with horn button. Thanks for any help.
