A better use for Coke or Pepsi
Posi
Always Off-Roading Jeeper
New England
54 Willys 3B, FI 401, T-18, ARB Locked, Hinkey Sidewinder Winch
As a cleaning agent. I typically don't drink the stuff, but do use it with aluminum foil to clean chrome.
I restored a family member's 28 year old bicycle bell. Given the dings and scratches it came out decent.
Certainly a good product to use for cleaning rusted stock Renegade chrome rims, and other chrome Jeep parts.
I've N E V E R heard of this...??? Why does it work so good?
Two reasons, coke/pepsi is very acidic, slightly more then battery acid on the PH scale. Aluminum is soft enough that is won't scratch the chrome yet abrasive enough to remove the rust.
Well now I can clean up my headlight trim rings instead of paying Crown $65 for a new set...
Thank you!
Thank you!
I would bet the Crown ones would look worse in a year then the ones you have now.
Wow, thanks for the info! Going to try this on my OEM wheel that I still use for my spare. Same thing about the light trim...
Have to look at the process. Do you soak it before or just apply with a brush and then scrub with alum?
I didnt soak it, the bell was small enough that I could clean it in a cut down plastic bottle you see in the first picture.
For larger items I use a spray bottle filled with coke. Just spray on rusted chrome and scrub with aluminum foil. The AF wears after a bit so you will need to grab a new piece every so often depending on the amount of rust.
No wonder my colon was so clean! Truthfully, I use to drink 6 to 8 cokes a day. Really ate the enamel of my teeth. Lots of acidity in it. I've used the stuff to clean battery terminals, etc. but not chrome. I'll have to give it a try, thanks!
Wait What... that totally dosent look like the same bell :eek::chug: .... speaking of which im thirsty time for a coke
