CJ3a
CJ3a
BusaDave9
Always Off-Roading Jeeper
Durango, Crawlarado
1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
Willys Overland CJ-3A
The above image is from The CJ3A Information Page
This is Gary Keating's CJ3a
The Willys Overland CJ-3A was produced from 1949 to 1953. It was to replace the CJ-2B. The most noticeable difference is the windshield of the 3A has the wipers on the bottom. Willys Overland made other changes to give the driver more room. The driver seat was moved back but it still had a 80 inch wheelbase. It had a taller windshield gave more headroom. All CJ3b's came with a 6 volt electrical system that included a generator. It is a common mod to upgrade to a 12 volt system with an alternator.
Engine
The Willys L134 "Go Devil" engine was used in the CJ-3A. It was a 4 cylinder that produced 60 horsepower and was nicknamed the “L134 "Go Devil"”. While the majority of automotive engines have the valves in the head, this engine was an L-Head design. That meant the valves were in the engine block.
The above photo is from Wikimedia Commons
Drive-train
The CJ-3A came with the T90 three speed transmission.
Click here for more info on the T90. -->> https://jeep-cj.com/community/threads/manual-cj-transmissions.43554/#post-394889
The transfer case was the Dana 18. Click here for more info on the Dana 18. -->> https://jeep-cj.com/community/threads/transfer-cases.43552/#post-394879 This TCase came from the factory with twin shift levers. The rear output is on the passenger side. It is a strong transfer case. Warn made an overdrive for the Dana 18.
The front axle is a Dana 25 with an enclosed steering knuckle.
Originally Willys Overland used the Dana 41 rear axle in the CJ-3A. Starting in 1951 the Dana 44 was used.
Accessories
The CJ-3A was often used on farms. The CJ-3A could be used to plow.
There was a lot of accessories that could be attached to the PTO.
The above photo is of Jay Newsome's plow from cj3a.info
CJ3A Production Numbers
Prices are from "A Standard Catalog of Jeep" by Patrick Foster
production numbers came from "Jeep, Illustrated Buyers Guide" by Jim Allen
The M38 was the military version of the same jeep. Here is one I saw in Silverton CO. I modified this picture with HDR software.
And here is the interior a a CJ3a.
