Help Disc-Disc Brakes
Patrick
- El Paso, TX
- 82 CJ5, LS 6.2, NV3550/D300, D44/30
68 CJ5, 350, Muncie/D18, D44/27 under construction
Having my coffee here and would like to rationalize this thread.
The only favor you are doing to yourself by relocating the prop valve is that it makes for an easier replumb job. I did it on my rig. If all you are doing is replacing the valve and no replumb, then the relocation is not warranted. When all is said and done, and done correctly, you will not have to fiddle again with this valve ever again.
That aftermarket power brake kit from the Jeep Guy does require replumbing. A good quality tube bender and flaring tool are key. And anything less than a double flare on brake lines is a no no.
On another note, I can theorize that the bigger Chevy calipers used in conjunction with a high quality manual brake setup might rival the stopping power and pedal effort of power assist brakes, and might negate the need to replace the prop valve all together due to their bigger cylinder size. And keep things simple.
