Favorite tool?
Favorite tool?
That old blue wrench is a very handy tool for sure! :)[/quote]
I have to agree on that one, at times it's the only tool that will get the job done.:chug:
here is a list of favorites and what they do
DRILL PRESS: A tall upright machine useful for suddenly snatching
flat metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, denting the freshly-
painted Jeep hood which you had carefully placed in the corner
where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them
somewhere under the workbench with the speed of light.
Also removes fingerprints and hard-earned calluses from fingers in
about the time it takes you to say, "Oh sh!#..."
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the
creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert
minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija
board principle. It transforms human energy into a crooked,
unpredictable motion, and the more you attempt to influence its
course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off
bolt heads. If nothing else is available, they can also be
used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong
the conduction of intense welding heat to the palm
of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting
various flammable objects in your shop on fire.
Also handy for igniting the grease inside the wheel hub out of which
you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch
wood projectiles for testing wall integrity.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder
than any known drill bit that snaps neatly off in bolt holes thereby
ending any possible future use.
BAND SAW: A large stationary power saw primarily used by most shops
to cut good aluminum sheet into smaller pieces that more easily fit into
the trash can after you cut on the inside of the line instead of the
outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile
strength of everything you forgot to disconnect.
CRAFTSMAN * x 24-INCH SCREWDRIVER: A very large pry bar
that inexplicably has an accurately machined
screwdriver tip on the end opposite the handle.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals
under lids or for opening old-style paper-and-tin
oil cans and splashing oil on your shirt; but can also be used, as
the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes
used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip
or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer
nowadays is used as a kind of divining rod to locate the most expensive
parts adjacent the object we are trying to hit.
DAMMIT TOOL: Any handy tool that you grab and throw across the
garage while yelling 'DAMMIT!' at the top of your lungs. It is also,
most often, the next tool that you will need. __________________
Baja, I'm still ROTFLMAO, that was too funny!!
My favorite tools are the 3/8 air ratchet (compressed air required, of course) and the impact screw driver, you know, the one you hit with the hammer. The air ratchet saves so much time and the impact driver is the only way to remove Torx body bolts.
I have just discovered a home made penetrating oil that so far has worked better than anything I have found in a can. I mix equal parts of acetone and ATF. If you have a chance to try it let me know how it works for you the only things I have used it on had been setting in WD 40 overnight and would not move, used this and in 5 minutes it the parts were loose, maybe it was just time. It is hard to be scientific about this but I keep a squeeze bottle with a cap of this stuff and try to remember to keep it away from painted surfaces and open flame. I also found that if I drop one of those magnets they salvage from old hard drives in the bottle it will stick to the fender and is so much harder to spill.
i like that magnet trick, thanks
It's simple, but I'm going to have to go with my safety wire tool. Other then being fun to use, it is really handy for quick and creative repairs. Also looks trick if you do it right.
PB Blaster, cause i dont have a torch. this site is also a great tool, if you got a question chances are somebody on here is going to have an answer
I was looking at the premiere weld today at the offroad expo, I want I want
I would have to say my angle grinder. Before I had many of the tools I have now, I used it for just about everything. Cutting body rust out, stripping paint, rusty stripped out bolt, no problem! I even used it to cut out rocker guards out of 3/16th diamond plate! It took forever.
Do avoid grinding Aluminum, it loads the wheel up and expands with the heat build up, breaking the wheel, angle grinding wheels are fiber reinforced so the pieces that break off are not going to be very big but they are flying oh so fast. And never even think about grinding aluminum with a rock grinder, the shrapnel is a lot bigger.:eek:
Skill saws with carbide tooth blades work very well on aluminum diamond plate.
safety reminder; you never have to remind a one eyed man to wear safety glasses.:laugh:
That's good to know, thank you. I was cutting steel diamond plate, and it did get a little scary at times. I broke a few wheels, and shrapnel went a flyin! I wore my welding shield, and leather gloves! It's nice to have the right tools for the job now.
My absolute favorite tool is the cocktail hour flag, when ever it is raised, all work stops for the day and we go inside for a few adult beverages. My wife bought that tool for me years ago and explained the rules to me. I think she knows when I am frustrated and doing more harm than good so one day I saw it in the garage. I also noticed it was on a cam so it could be up or down. So I asked and she said, "You are king in here, allowed to do what ever you want, but sometimes I can tell you need a brake so if I raise that, you come in and have a beer or 2. Otherwise I will not be here when you are so mad you start throwing stuff." It works great and has actually been a benefit to my career as an amateur mechanic.
My motto: Why not? I can always weld it back together... :)[/QUOTE]
ROFLMAO!
Right now it's my Hobart Stickmate because I have been restoring the Scrambler frame and this baby is my right hand man. Actually it's my left hand man because I weld lefty. I like ARC welding the best because it is harder and more satisfying to get right. Plus gas supply is not and issue.
I think pretty soon my favorite will be this monster...
My new favorite. Programing modules made easy.
$100.00
  50.0%
