Misc. Found my new engine.
- Central FL
It runs on pump gas!
https://www.sonnysracingengines.com...re-space-hemispherical-headed-pump-gas-engine
SONNY'S 940 CU.IN. 5.3 BORE SPACE HEMISPHERICAL HEADED EFI PUMP GAS ENGINE (1700HP)
DESIGNED TO RUN ON 93 OCTANE PUMP GAS........FOR ALL YOU DIE HARD STREET ENTHUSIASTS, THIS IS THE WOW FACTOR ENGINE!!!. THIS MONSTER 940 CU. IN SONNY LEONARD HEMISPHERICAL HEADED STREET ENGINE PRODUCES OVER 1700 HP ON 93 OCTANE UNLEADED FUEL, YES, ON 93 OCTANE UNL FUEL!!! THE 940 WAS BUILT FOR THE HARD CORE STREET CAR ENTHUSIAST, THAT NOT ONLY WANTED THE ULTIMATE IN PERFORMANCE, BUT THE WOW FACTOR!!. WITH SONNY'S HEMISPHERICAL CYLINDER HEADS, THIS ENGINE IS SURE TO DRAW ATTENTION, AND HEAD SHAKING, THE 940 ENGINE FEATURES ALL THE LATEST TECHNOLOGY AND IS MADE FOR A WEEKEND GETAWAY. IT FEATURES ALL THE BEST COMPONENTS, FOR DRIVEABILITY, AND RELIABILITY. CALL AND ORDER YOURS TODAY
Price: $95,600.00
FEATURES
Sonny's fully in-house CNC ported hemispherical cylinder heads
Sonny's/5.300 B.S. block with 2.000" raised cam with special hi-flow water jackets
Bryant billet crank
Carrillo Steel Billet rods
Wiseco endurance pistons
1.062 Jesel Keyed lifters
Tool steel taper-wall pins
Total Seal rings
Manley titanium valves & PSI valve springs
SAR/T&D rocker system
Trend pushrods
Sonny's cam belt drive
Dailey 5 stage dry sump oiling system
ATI balancer
MSD cranktrigger ignition
SAR sheetmetal intake manifold
SAR/Accufab throttle bodies
Big Stuff EFI with run map & car harness
SAR Billet valve covers
Mezier hi-torque starter
High Amp 12 or 16v Alternator
Fuel lines with regulator
Sonny's/Special design 70mm camshaft
But you can save $2500.00 with an EFI delete.
Price: $95,600.00
FEATURES
Bryant billet crank
Total Seal rings
Trend pushrods
ATI balancer
