Brakes Frozen brake fitting
Genaz
Rochester, NY, USA
1979 CJ7. 258cu 6cyl. T5 tranny/Dana 300 transfer case (both from '82 Scramber)
Hi, can't break a fitting loose on the proportioning valve to install longer brake line up to new master cylinder. Last resort is heat. Does anyone know if this will damage the proportioning valve? It's hard to get at and has started to round off, even with line wrenches.
If your replacing it cut it and put a socket on it and hit it with an impact
Tough and tight spot. But maybe a thin wall socket. Really frustrating with these little issues. But almost done. Thanks!
You can gain a little room by un bolting it from the frame and pulling it out without removing the other lines
