Misc. Fun with ChatGPT AI
Featured
Thought I would experiment with ChatGPT with some Jeep questions including some asked in the forums.
I asked -->>
"What is better, a jeep CJ5 , CJ7 or CJ8 ?"
The reply. -->>
"Choosing between a Jeep CJ5 , CJ7 , or CJ8 comes down to personal preference and needs. Each model has its own unique features and characteristics.
The CJ5 is a classic Jeep model that was produced from 1955 to 1983. It has a short wheelbase and is known for its maneuverability and off-road capabilities. The CJ5 is a popular choice for off-road enthusiasts and collectors.
The CJ7 was produced from 1976 to 1986 and was designed with a longer wheelbase than the CJ5 . This increased stability and allowed for more interior space. The CJ7 is also known for its off-road capabilities and is a popular choice for both off-road enthusiasts and daily drivers.
The CJ8 , also known as the Scrambler, was produced from 1981 to 1986 and is a unique Jeep model that features a longer wheelbase than the CJ7 . It has a pickup truck bed and is a popular choice for those who need both off-road capabilities and cargo space.
Ultimately, the choice between a Jeep CJ5 , CJ7 , or CJ8 depends on your personal preferences and needs. If you prioritize maneuverability and off-road capabilities, the CJ5 might be the right choice for you. If you need more interior space and stability, the CJ7 might be the better option. And if you need both off-road capabilities and cargo space, the CJ8 might be the way to go."
Thought I would try this thread. -->> Engine - Edelbrock intake for my new 360 question
Question -->>
"What intake gasket should I use for an AMC 360 with an edelbrock performer intake?"
Reply -->>
"To select the right intake gasket for your AMC 360 with an Edelbrock Performer intake, you'll need to consider a few factors, such as the year and model of your engine and the size of your intake ports.
Edelbrock recommends their own intake gasket for the Performer intake. The Edelbrock intake gasket part number 7235 is designed specifically for AMC V8 engines with the Performer intake. It is a high-quality gasket made from a composite material and features a raised bead around the ports for a secure seal.
Another option would be Fel-Pro's gasket part number 1240. This gasket is also designed for AMC V8 engines with the Performer intake, and it features a steel core for added strength and durability.
Ultimately, it is recommended to consult with the manufacturer of the intake manifold (in this case, Edelbrock) to ensure that you get the best performance and compatibility from your intake gasket."
Continued -->>
"what about a valley pan type?"
Reply -->>
"If you are considering a valley pan gasket, there are a few factors to consider. Valley pan gaskets are designed to seal the area between the engine block and the intake manifold, preventing oil leaks and improving the overall sealing of the engine.
For the AMC 360 engine, there are a few different options for valley pan gaskets depending on the specific year and model of your engine. One option is the Fel-Pro VS 50069 R valley pan gasket, which is designed specifically for AMC V8 engines with a rear oiler configuration. Another option is the Edelbrock 7276 valley pan gasket, which is designed for the Edelbrock Performer intake manifold and features a high-quality composite construction.
It is important to note that not all intake manifold setups require a valley pan gasket. The Edelbrock Performer intake manifold, for example, does not require a valley pan gasket for proper installation. Therefore, it's always recommended to consult the manufacturer's instructions and specifications to ensure that you are using the correct gaskets for your specific engine and intake manifold combination."
Pretty cool.
Thought I'd try another...
-->> list the best equipment that i should bring or have for my jeep CJ7 when four wheeling in moab
"When four-wheeling in Moab, it's important to have the right equipment to ensure that you and your Jeep CJ7 are prepared for the challenging terrain. Here are some essential pieces of equipment you should consider bringing:
  1. Good-quality all-terrain tires: These will help provide the necessary traction on the rocky and uneven terrain in Moab.
  2. Lift kit: A lift kit will provide additional clearance and improve the Jeep's approach and departure angles.
  3. Skid plates: Skid plates will protect the undercarriage of your Jeep from damage on rocky terrain.
  4. Winch: A winch is essential for self-recovery in the event that you get stuck.
  5. Recovery gear: This includes tow straps, shackles, and a high-lift jack to help recover your Jeep if it gets stuck.
  6. CB Radio: Communication with other vehicles in your group is essential, and a CB radio will allow you to stay in touch.
  7. GPS or Navigation system: The terrain in Moab can be challenging, so having a reliable navigation system can help you stay on course and avoid getting lost.
  8. First-aid kit: Accidents can happen, so it's important to have a first-aid kit on hand in case of injury.
  9. Fire extinguisher: A fire extinguisher is important in case of a vehicle fire.
  10. Portable air compressor: You may need to adjust tire pressure on the fly depending on the terrain, so a portable air compressor will come in handy.
It's also important to make sure that your Jeep is in good mechanical condition before heading out on the trail."
-->> list 10 more necessary vehicle modifications
"Sure, here are 10 more necessary vehicle modifications that can improve your off-road capabilities and overall driving experience:
  1. Locking differentials: Locking differentials provide equal torque to both wheels, improving traction and allowing you to overcome obstacles more easily.
  2. Upgraded suspension: A better suspension system can improve your Jeep's handling and stability, especially when driving off-road.
  3. Off-road lights: Additional lighting can improve visibility on the trail, making it easier to navigate difficult terrain at night.
  4. Snorkel: A snorkel raises the air intake to the roofline, allowing you to cross deep water without worrying about water entering the engine.
  5. Rock sliders: Rock sliders protect the sides of your Jeep from damage when driving over rocky terrain.
  6. Upgraded brake system: A larger brake system can provide better stopping power, especially when carrying heavier loads or driving downhill.
  7. Bumpers: Upgraded bumpers can provide better protection for your Jeep's body and improve your winching capabilities.
  8. Skid plates: Skid plates protect the underside of your Jeep from damage when driving over rocks or other obstacles.
  9. High-performance exhaust system: An upgraded exhaust system can improve engine performance and fuel efficiency.
  10. Performance chip: A performance chip can increase horsepower and torque, improving your Jeep's off-road capabilities."
Thought I'd try this thread. (Link)-> Steering - Another loose-*** steering post -<
Not a bad set of replies. Kinda scares me a bit...
Question by @RI CJ5 :
So I just bought a 1980 CJ5. 360, 4" lift, 33's. PO did a frame off resto. Beautiful work. Everything is new and tight and clean. But the thing wanders all over the road. I have been searching the web for days but outside of " That's just the way they drive" {which is true to a point, but I had an '85 with 33's and a 3" lift and it wasn't nearly as bad} and "Mine drives nice at 90mph on the highway" which sound like a dream, there is nothing I can see to do. Steering box has no play although I cant adj due to stripped allen nut. So, besides adding a steering stabilizer, which will help but not cure. I can see the springs flex side to side when I turn wheel. Whole body shifts, but don't want to crank shackles any tighter and all tie rod ends are tight. So, are there any other ideas out there?
ChatGPT said:
It sounds like you've done a good job investigating the common causes of wandering in a CJ5. Since you've already checked the steering box, tie rod ends, and the overall condition of the suspension components, there are a few other possibilities to consider:
  1. Alignment: Ensure that the front end is properly aligned. Improper alignment can lead to wandering issues. Check the caster, camber, and toe settings. A proper alignment can significantly improve the vehicle's stability.
  2. Tire Pressure: Uneven tire pressure can cause the vehicle to pull to one side or wander. Make sure that all tires are inflated to the recommended pressure, and the pressures are consistent across all four tires.
  3. Wheel Bearings: Worn or loose wheel bearings can contribute to wandering. Inspect the front wheel bearings for play and replace them if necessary.
  4. Axle U-Bolts: Ensure that the axle U-bolts are properly torqued. Loose U-bolts can allow the axle to shift and contribute to wandering.
  5. Steering Dampener: While you mentioned adding a steering stabilizer, make sure it's in good condition. If it's worn or not functioning correctly, it may not provide the necessary dampening effect.
  6. Suspension Bushings: Check all suspension bushings for wear and tear. Worn bushings can allow excessive movement and contribute to wandering. Pay special attention to the bushings on the leaf springs and shackles.
  7. Frame Twist: Since you've mentioned the body shifting when turning the wheel, it might be worth checking if there's any frame twist or flex. A frame that's not properly aligned or reinforced can contribute to handling issues.
  8. Driveline Angles: Verify that the driveline angles are correct. Incorrect driveline angles can cause vibrations and affect the stability of the vehicle.
  9. Steering Linkage: Inspect the entire steering linkage for any worn or damaged components, including the drag link and track bar.
  10. Shock Absorbers: Ensure that the shock absorbers are in good condition and are the appropriate type and length for your lift. Upgraded or adjustable shocks may help improve stability.
If you've gone through these checks and the issue persists, it might be helpful to consult with a Jeep specialist or a professional alignment shop. They may be able to provide more specific guidance based on a hands-on inspection of your CJ5.
I continued the conversation:
Code:
Every thing is brand new from a complete full vehicle rebuild.
Chat GPT said:
Given that everything is brand new from a complete rebuild, it's a positive indicator that major components are likely in good condition. However, even with new parts, there could be subtle issues that are contributing to the wandering. Here are a few more specific suggestions:
  1. Check for Frame Twisting: Ensure that the frame is not twisted or misaligned. If the frame is not straight, it can lead to handling issues. This might involve taking measurements to confirm that the frame is square.
  2. Verify Suspension Geometry: Confirm that the suspension geometry is set up correctly. This includes checking the caster, camber, and toe settings. Incorrect suspension geometry can result in poor handling.
  3. Inspect Steering Geometry: Verify that the steering linkage and components are installed correctly and that the steering angles are within specifications. Incorrect steering geometry can contribute to wandering.
  4. Recheck Alignment: Even if the alignment was done during the rebuild, it's worth double-checking to ensure that it's within spec. Sometimes adjustments need fine-tuning.
  5. Tire Balancing: Ensure that all tires are properly balanced. Imbalanced tires can cause vibrations and affect steering stability.
  6. Axle Centering: Make sure the front and rear axles are properly centered. An off-center axle can lead to handling issues.
  7. Verify Suspension Bushings: Although everything is new, recheck the bushings for signs of binding or misalignment. Sometimes, even new bushings can cause issues if they are not properly installed.
  8. Check for Loose Fasteners: Ensure that all nuts and bolts on the suspension components are torqued to the manufacturer's specifications. Loose fasteners can lead to instability.
  9. Inspect Steering Damper: Since you mentioned that a new steering stabilizer will help but not cure the issue, it's still worth confirming that the steering damper is in good condition and properly installed.
If you've gone through these additional checks and the wandering persists, it might be helpful to consult with the shop that performed the rebuild or seek the expertise of a specialized Jeep mechanic. They may be able to identify any specific issues related to the rebuild process or provide insights based on their experience with similar builds.
My last information given:
Code:
The front axle does have six degree spring pad shims..
ChattGPT said:
The use of six-degree spring pad shims indicates that an effort has been made to correct the pinion angle and potentially improve driveline angles. However, it's crucial to ensure that the shims are installed correctly and that the pinion angle is within the recommended specifications.
Here are a few considerations regarding the use of spring pad shims:
  1. Pinion Angle: Confirm that the pinion angle matches the transfer case output shaft angle. The goal is to have the pinion angle parallel to the transfer case output shaft to minimize vibrations.
  2. Proper Installation: Verify that the shims are correctly installed, and there are no issues with alignment. Misaligned shims or improper installation can affect the suspension geometry.
  3. Driveline Angles: Check the angles of the driveshaft(s) to ensure they are within acceptable limits. Proper driveline angles are crucial for smooth operation and to avoid vibrations.
  4. Axle Centering: Confirm that the front axle is centered both side to side and front to back under the vehicle. An off-center axle can impact handling and steering.
  5. Inspect U-Joints: Examine the universal joints on the driveshaft for any signs of binding or wear. Worn U-joints can cause vibrations and affect overall drivability.
  6. Consider Adjustable Control Arms: If needed, adjustable control arms can provide more flexibility in setting the correct pinion angle and optimizing suspension geometry.
It's important to note that while six-degree shims are a common solution for correcting driveline angles, the specific requirements can vary based on factors such as lift height and other modifications. If you're uncertain about the correct setup, consulting with a knowledgeable Jeep specialist or suspension expert could provide valuable insights and assistance in fine-tuning your CJ5's suspension geometry for optimal performance and stability.
So where does the ChatGPT get all its info from ?
My answer: All from the WEB. It takes the info and intelligently sorts and composes answers or formulations based on algorithms and learning.
I posed your question to ChatGPT:
ChatGPT said:
I don't have access to the internet or real-time information. Instead, I was trained on a diverse range of data sources, including books, articles, and websites, up until my last update in January 2022. I don't have the ability to pull in information from the web or databases in real time. If you have any questions or need information, I can do my best with the knowledge I gained during training, but I won't have data on events or developments that occurred after January 2022.
I then asked: Why only up to Jan: 2022?
ChatGPT said:
As of my last training cut-off in January 2022, that was the most recent dataset available. My training data consists of a snapshot of diverse information collected up to that point. While this allows me to provide information and generate responses based on a wide array of topics, I don't have access to events, discoveries, or changes that occurred after that date.
Keeping the training data fixed allows for consistency in responses and helps manage the ethical and privacy concerns associated with using real-time data. It's important to note that I'm a tool designed to assist and provide information to the best of my training, but for the latest and most accurate information, it's always a good idea to check the most recent sources.
That’s what I was thinking. Maybe it’s good we might not let AI control the nukes. Hopefully they are not letting Tic Tok teach it. :doh:
I saw they disbanded their safety team.
