Pertronix help
Pertronix help
Montanaphilly
Apple valley
None
I'll try to summarize, I know all of you dont want to read a novel , I have a dj5 mail jeep I did a 4x4 conversion on. Is has the inline 6 232, i bailed on the points and went with the pertronix ignition. Is it needed to use a relay for the red wire (we'll call it positive)? Reason I'm asking right out of the box I wired the red wire to the positive on the coil and it will run for a while and die, blow fuse after fuse after fuse. I'm electrical savvy, just wondering if anyone out there can give me a forsure on what the hell is going on. CHEERS , ITS FRIDAY.
Sent from my SM-N960U using Tapatalk
I don’t remember you needing a relay, my buddy had 3 sets and it was a stupid easy swap, what fuses are you blowing?
