Trans T5 gearbox oil
Hi what oil is everyone using in the T5 gearbox 1084 cj7, been told l can use ATF fluid is this right
75W-80 syn gear oil.
No ATF....
Gary
GL4 gear lube. Do not use GL5. GL5 does not replace GL5. I had to educate the guys at NAPA about that; they insisted that GL5 was "improved" over GL4. They have, in fact, different chemistry and GL5 isn't appropriate for any of these older gearboxes... especially not manual transmissions with brass synchromesh.
Order Part #: SL SL24229 have it ship to your local Napa for free pickup.I had the exact conversation with the folks behind the counter at my local NAPA yesterday. I asked if they had any GL4 gear oil in stock and they looked at me weird. Then I asked if they had any gear oil safe for manual transmissions with brass synchros. The lightbulb seemed to turn on and they gained my confidence back...until they handed me a jug of synthetic GL5 that read in both bold and italic: "not suitable for transmissions with brass synchros"
The hunt continues for a local place to avoid shipping costs...
hole is using the correct factory recommended lube as it falls under the SM 9224 specs as listed above (Pennzoil 3501 GL4 5W20)Pennzoil Synchromesh
FWIW, I am running 50w oil in my T176. Factory says 80w gear oil but it gets cold in the winter and 50w seems to cause less stress to my transmission in the cold.Hey Posi can you do that for the T176 ? Just got rid of my T4 and going with a T176 when I get it in. Seems like i saw a Couple for it.
As long as it contains no molybdenum disulfide, or any other form of molybdenum, which actively corrodes brass. Its MSDS isn't forthcoming about what it contains, which makes me suspicious.FWIW, Modern Driveline recommends either Amsoil Dexron II synthetic for "most T5" transmissions, or for the non-World Class T-5 they specifically list Lucas synthetic 50 Wt truck transmission oil. O'Reilly's can order it, part 10146, in 1 gallon jugs.
