Misc. Where to mount ARB compressor?
aglinks
Flagstaff, AZ
‘83 CJ7, 4.8L Vortec, TF999, D300, AMC20, D30
Hey all,
I picked up an ARB High Output Compressor (CKMA12) and am trying to figure out a good mounting location. My engine bay is already pretty packed with the LS swap. Where have people mounted this so that it is out of the way? I thought about mounting to my roll cage but I can't find a good off the shelf mount and my fab skills are terrible. Thoughts?
Here's a post about my OBA setup and mounting. I have the same space issue under the hood with my engine swap. My compressor is not an ARB and I don't know the dimensions of yours, but mine fit nicely between the inner and outer fender with a 3-gallon tank under the driver side mounted to the frame.
OBA Setup Link
You're gonna laugh, but I mounted mine in the glove box
Or where the glove box used to be, I should say...took it out...drop the door to access
I was happy with how it came out
That’s pretty awesome! I have future plans of putting a radio/intercom system there.
If you can, post pictures once installed.
I still need to wire/plumb it. But the modified bracket worked perfectly!
