1-1/2" tpf tie rod taper reamer
Thorwon
Commerce Ga.
1966 CJ5 134"F" 3sp with Warn OD
Anybody got a tie rod reamer I could borrow or rent?
I want to make some inserts to flip my tie rods.
I can turn them to size and bore them close to size on my lathe but I would like to have a reamer to finish the taper with.
Sorry I borrowed the one I used.
I was going to make my own also, but at $10 each it wasn't worth my time so I just bought them.
They are tappered on both the inside and the outside.
I'm not going to use the double tapered insert. I'm going to drill the arm out to 3/4" and put a flange on the insert. The only taper will be inside.
Thanks CJ that would be great!!
Is there anything you DON'T have?:notworthy:
