1" Shackle Lift?
1" Shackle Lift?
Shazam
North Carolina
1979 CJ-5 Renegade with '74 304 V8 & Edelbrock manifold & carb, Heddman headers & sidepipes, T-150 3 speed, Dana 20, Dana 30, AMC 20
Hi guys. I'm getting ready to add a 1" shackle lift using the 1 piece "H" design (like Warrior) shackles. I don't do any serious wheeling, but had a couple of questions:
Will a 1" lift negatively affect my steering/driving?
Do I need greasable bolts if I'm keeping my rubber bushings or will regular bolts (like stock) work?
Thanks!
A question to consider. Is an actual 1/2" lift really worth the effort for you?
Some say that a grease able bolt is weaker that a solid one. I was advised not to use them.
Thanks!
I did this on the front only to level my CJ out and have zero regrets. Just use rubber bushings and regular bolts, just don't overtighten them.
I used a 2" longer shackle for a net 1" lift up there and it's perfect.
1/2 inch of lift will really not effect the steering angle much. our machines are neanderthal in design in that area anyway so they have a bit of leeway. UNLESS you want to do high speeds
I do use shackle lifts on my 67 CJ5 but only on the rear, I wanted flatter springs and less flex back there. I have 2 inch lift springs and 2 inchs of lift in shackles back there to match the 4 inch lift on my front end. No I did not want to mess with steering angles and wanted full flex up front.
ans remember what has been stated, 1 inch of shackle is not going get you 1 inch of lift.
Thanks all. Sorry for the late thank you but I'm having problems logging in.
