    Thank you for your support!
1977 Dana 30 Quadratrac Axle??
Yes! I just did the same into my '69 CJ5 . Added Warn Hubs.
rocmoc n AZ/Mexico
Thanks man. Been searching the web for the past two hours and finally looks like I can just bolt them on.
