1986 Ignition Problems
Panky
not to get in your post but im having problems with my 86 CJ7 4cyl too. cant get it running and its making nuts already. im a nowbie could you help. i bought it couple months ago and wanna restore it. ok first it had a bunch of water in gas tank(it didnt have the gas lid for months i guess). it wont start. ive made it new pretty much. things ive put new so far:
tank sending unit( also emptied the gas and put new gas)
fuel hoses
fuel pump
fuel filter
open and cleaned carb
spark plug wires
coil
ignition module
starter
starter solenoid
ignition switch
key ignition
and thats it i think
so...
when i bought it i disconnected the fuel hose before the fuel pump and put a little gas tank and it started nice and calm(better than my daily driver). i havent adjusted the ignition switch i guess( before i bought the switch, the switch rod used to get stuck and didnt want to spring back. dunno if it still does it). i took the plugs off the ignition switch and wired an universal key switch from autozone to try to start it and nothing. i have to play with the key switches to crank it( ive tried 3 key switches and 3 solenoids) until it cranks(like the solenoid is stuck or the switch doesnt make the right contact).
i put the key in start position, i get spark and gas(feels like i wants to start)
i put gas directly inside the carb and wants to start more(even get some smoke out tail pipe)
. as soon as i put the key in run position i stop getting sparks at the spark plug wires and suddenly the engine doesnt feel like starting
what do you think guys? i think on doing a nutter bypass to cut out the computer too, should i?
any help, thoughts would be greatly appreciated since i just feel like burning the damn thing by now
fuel hoses
fuel pump
fuel filter
spark plug wires
coil
ignition module
starter
starter solenoid
ignition switch
key ignition
so...
. as soon as i put the key in run position i stop getting sparks at the spark plug wires and suddenly the engine doesnt feel like starting what do you think guys? i think on doing a nutter bypass to cut out the computer too, should i?
