2 1/2 inch lift and Pitman Arm
RTRCJ7
- Media
- 5
- Metro Atlanta
- 1983 CJ7 Loredo ,restored, straight 6 , 4 speed
How much of a dif in handling will I see if I go to a 4in drop pitman arm?
I have a 5in suspension lift and it still has the straight original arm.
I'm doing almost the same thing on my 3b and from what was told I wouldn't need to change pit-man arm but it may also depend on the lift
It is 10x better than when I got this a few weeks ago.New steering shaft and column bushing.But has more of a wandering than the jerking than it did.It will correct your sttering geometry, If you have a really bad wander, it will help with that. How bad is you steering now?
You don't have to worry about te pitman arm until you get up to around 4 inches. 2.5" you will be ok with the stock arm.
