Help 3.73 gear ratio, what size tire
ColoradoDerek
Good Afternoon all.
I know this question is highly discussed with many opinions across the internet but I figured I'd just ask again anyway and see what YOU guys thought.
I have a Dana 30 front end, Dana 20 Transfer Case , AMC20 rear end and a T-150 Transmission .
My gear ratio is 3.73 and my current tire size is 35". The engine is a AMC 360.
Should I go down to 33" or even 31" tires with this setup? In what scenario would my axles be under too much stress from 35" tires and a 360 motor that they would "snap" or otherwise break? Is that going to be if I'm going hardcore rock climbing day in and day out they will eventually break or is it so touchy that the first rock I try to climb over on a normal trail will break my axles due to my tire size, etc.
I have also heard that with that gearing and my larger tires that going up hills and other climbing will require a lot more "revving" of the engine to keep it going due to the size. How true is that and how much of a difference is a 31" or 33" tire going to be compared to a 35" for "climbing" scenarios?
I want to stay with 35's because I like what they look like but if I need to go down to 33's or even 31's to keep my rig safe and unbroken I can and will.
I can't find any solid information either way on the internet. Half the people say for a 35" tire you need 4.58 ratio minimum or something and others say they have 3.73 and do fine with 35's but I also question whether these people have newer, modern jeeps or old stuff like me. Even more people say 33's are the best for a Dana 30 /AMC20 with 3.73 so it's just impossible to find a clear answer, however, right now, before hearing your guys opinions, I'm leaning towards 33's being what I should shoot for.
Since you guys are CJ orientated hopefully I can get some better idea of what I need to do from your opinions.
My goal is to make it so my axles don't snap while I'm driving around. keep in mind, I live in CO and have some badass trails around here so it's possible I could run into a "hardcore" situation just while out "casually" trail riding and I'm wanting to be able to do/try those scenarios without fear my axles will snap.
Thank you!!
EDIT: I Found this old post of mine:
https://jeep-cj.com/community/threads/tires-too-big-for-my-drive-train.66413/#post-566426
which has some information in it to but I figure my question here still stands since now I know all my parts.
After reading that post again though, I'm LESS leaning towards 33's but still kind of am.
-derek
Thank you!!
-derek
