3" body lift steering adjust
I'm not sure if the shaft is really supposed to be telescopic but it made it easy to remove when the 2 pieces slid apart. When I am rock crawling I can hear the shaft compress and extend. I think there is plastic in there. Get out the torch.
Sounds like a good mandate.The plastic was designed to shear and collapse. Federal mandate to eliminate the column from going through your chest on impact.
Mine moves by design yet will still collapse. Flaming river
Really helps from taking out your steering gear input seal when you're twisting your frame offroad.
