3 point seat belts
3 point seat belts
Flipper
Danville IL
'10 Huyndi Elantra
'76 CJ
where and how should i attach the sholder part of the seat belt on my 76 cj:confused:? I was thinking of adding it to my roll bar
That is were my shoulder strap is attached.
It should be a rather simple operation. Just get a measurement where on the roll bar you would like to have it attached, and drill a hole in the bar big enough to weld a nut that fits the seat belt bolt into.
What I used to do when I built roll cages at my last job at a fab shop, was to drill trough the cage with a 1/2" drill bit, the open the outside hole up to 3/4", then weld a sleeve into the cage and run a 1/2" grade 8 bolt through the seat belt and the cage. That way it had the most support in the event of a roll-over or head-on. Just my .02.
