360 swap still the same problems
Chriss
South Germany
1983 CJ7, AMC 360, T176, DANA 300, Axles Stock with true trac, 33" Cooper STT tires, 4" lift by Trailmaster
1999 JEEP Grand Cherokee 4,7 stock. Family car
Yes I think the same with the frame alignment. Must I have a new frame now, or can I repair the frame? I hope I can repair it, cause I spend lots of money.:eek:
A good shop can usually straighten your frame.;)
I don’t see what year your CJ7 is but if you have a T150 I can only assume it is a 1976, 1977, 1978, or 1979. Make sure you have the skid plate installed using the front bolt holes in the frame leaving the back ones unused (The back ones are used when installing a T18.) loosen the skid plate up so you have some slop then move everything around until you can get the transmission mount to work then slowly tighten up the bolts moving from side to side as you do changing a tire. Sometimes it helps to use a come-along it things are stubborn but be gentle. I assume that all CJ frames were close to being square out of the box but 30 + years later, not so much.
Im sure you did this already but... are you running the AMC 258 i6 / 4.2l frame mounts or V-8 mounts.. they are different and count be causingthe issue with it leaning to one side
