4.0 budget rebuild
McSyd
Hi all, new poster, long time reader.
I’m in the midst of a full blown CJ7 restoration. I was planning to build a stroker for this Jeep but both AMC 258 i6 / 4.2l cranks I had were no good. So for now, to keep my project moving, I decided on a bare bones 4.0 rebuild. All stock. No mods at all.
Ended up needing 30 over bore and a valve job. Block and head were cut a total of 0.007” I believe he said (mighta been 11). Otherwise everything is pretty basic. This is my first proper engine job. So I need a little help from those who have rebuilt a 4.0 or AMC 258 i6 / 4.2l .
My plans are to keep this as basic as possible. I ordered a 2150 carb and HEI dizzy from eBay. Planning to run the AMC 258 i6 / 4.2l intake on the 4.0 for simplicity. I’m going to save the original 4.0 intake in case I want fuel injection down the road. But in all likelihood I’ll end up doing a Chevy 350 down the road.
So a few questions:
Can I or should I reuse the original head bolts. I don’t believe they’re stretch bolts due to the torque specs. I’ve heard different opinions on reusing the old ones vs new. The machinist didn’t recommend arp bolts for this build due to the torque requirements
Is there a way to reuse the oil pickup for the oil pump? Or should I just get a new one? Any tricks to getting the tube installed without the fancy tool?
Any major negatives with using the AMC 258 i6 / 4.2l intake? I’m thinking for simplicity, to just use it instead of the 4.0 intake since I’m going carbed. I might do fuel injection down the rd but we’ll see. So I did t want to mess with plugging the injection ports on the 4.0 manifold and boogering it up in case I need it later.
Figured I’d get an HEI dizzy. Will I still need to stock AMC 258 i6 / 4.2l ignition control module? Or can I just skip that all together?
Will I need the stock ecm for anything? Plans are to make this as basic as basic can be. Carburetor, distributor, electric fuel pump. I can’t think of any reasons I’d need the ecm or ignition module with this setup. But I could be wrong. If I do t need the computer for anything I won’t have to do a nutter bypass correct?
What do I need for a water pump? I read somewhere about needing a reverse rotation pump for the 4.0 in a CJ7 . If so, which way is “reverse”? Clockwise or counter clockwise as you’re looking at the front from the radiator?
This motor was from an xj. Believe it’s a 1992 block. It originally had air conditioning. I’m not gonna need that. Can I simply omit that and get a stock serpentine belt for a 4.0 without ac? What about a belt tensioner? Not sure my motor had one when I got it.
One thing that’s bugging me. I have the short block assembled. I installed the timing set and on the crank there is an oil slinger. It has a key way in it but pushes past the key and just sort of floats there. That can’t be correct can it? Does anyone have a photo of how they sit on the crankshaft inside the timing cover?
I’ve included a few photos. I have 2 small core plugs leftover. They’re about 1” in diameter. Can’t find anywhere on the 4.0 for these but I see on the AMC 258 i6 / 4.2l block there’s holes that size. Are these just extras in the kit for a AMC 258 i6 / 4.2l rebuild or is there in fact a location for these on the AMC 258 i6 / 4.2l ?
So a few questions:
