4.2-1 vs 6.32-1
4.2-1 vs 6.32-1
joseph
Arco Idaho
77 cj5 v8 3 speed. Fiberglass fenders.
76 cj5 T18 close ratio.
69 cj5. 289 Ford. 11 inch Ford brakes. Ring and pinions changed to higher. Chevy heater. Studebaker overdrive. Koenig PTO winch. Saginaw steering. Rancho springs Full cage. Running lights, work light out back. Custom spare tire rack. Hood scoop. Auxiliary electric fuel pump. Two gas tanks. Dual shocked. Snow plow. AM-FM eight track and another AM radio on passenger side dash. 32/11.5/15 mud tires. Did I mention hood scoop? Custom diamond tuck upholstery. Hurst shifter knob. 1975 windshield frame. Tilt and telescoping steering wheel. did I mention the Hurst shifter knob? Wall to wall carpet. Auxiliary gauges. No emergency brake, wha? Locker in rear. Still finding stuff.
Hello. Tried the search function but nothing happens.
Wondering what ratio to go with. I have a complete AMC 258 i6 / 4.2l -1 T-18 with TC intact and correct drive shafts. Wanting the 6.32-, but........?
Anyone have experience with both? My 79 CJ5 had the 6.32 so know what that was like.
Joe.
Biggest question is, how do you plan to use it? How big of tire are you running? What gear ratio ? Mostly street and very few rocks, 4-1 is fine.
354s, 31 inch tires. Highway, rough rocky roads round here. Want to crawl slow over the rough stuff.
6.32/1;)
lg
Sounds like a 6-1 would be better, upgrading the Transfer Case gearing would give a bit more too
I agree. My T-150 is 2.99. 4-1 won't give me what I want. Lower but not low enough. Had a chance to pick up a complete CJ for cheap. Had the four speed so jumped on it. My luck it has the rare? 4-1 box. I got a lot of spare parts now.
My 4/1 t'case was a great investment.
No regrets........:chug:
Got a AMC T-18 6-1 at the shop now getting a Ford input shaft installed. Hopefully will have it in the Jeep before snow flies.
