4 inch lift question
jeremy5780
South west FL
1985 cj7
putting a 4 inch suspension lift on my 1985 CJ7 and i had a quick question. my lift kit came with a set of leaf spring shims i know they go in the rear just not sure what way they face? fat end of the shim face to the front of the jeep or to the rear? Thanks guy's
fat end toward the front of the jeep.
Yes you want to tilt the diff upwards
Might need some in front too, check your caster when you get it together. Pretty common with a 4 inch lift to use long shackles that will throw off the steering caster.
