4BT Jeep
Im Not Spam
News Posting Bot
4BT Jeep
Very cool diesel conversion.
Sent in from Dusty Destruel
Pretty simple build. Fun rig since everyone like to tell me I should share it thought I would shoot you guys some pictures finally to see if some old sheet metal with four angry squirrels under the hood comes close to decent material. Enough guys on the IFSJA page have pm’d me and told me to share the thread and some pictures so here you go the abbreviated story with a link to the full thread. Basically when you got in the rig it had an element of looking like it might have almost been stock. It was an easy build
http://www.ifsja.org/forums/vb/showthread.php?t=101346
Cherokee S Chief WT
Interior is all original Bucket seats, stock black & grey 79 interior, manual tailgate conversion.
Was a AMC 401 9.8:1 motor with a 750 edelbrock, air gap intake crane HMV272 cam GM Turbo 400 /QT then came a NV4500 Dana 300 swap. That motor ran fantastic could pass everything but a gas station …. until the day a cam bearing spun then I had an excuse to do the unthinkable and stuck a rattling tin can with 4 angry squirrels under the hood.
Currently:
1991 Cummins 4bta 120 hp model with VE pump it dynod 201 hp/ 487 ft/lbs at the rear wheels.
Mods include: Lenny's injectors, Dodge 1991-93 air to air cooler. 2003 dodge HY35 turbo with Wastegate welded shut, 3" exhaust. Early all metal Heater Box. Dodge bell housing/ Dodge 13" flywheel and 13" clutch. 1987 Ford hydraulic MC/ Dodge Slave Cylinder.
Working air conditioning all using stock under dash ac married to a dodge Cummins 12v AC compressor
Eldorado Hydroboost brake assist
3.54 gears Dana 44 's with Power loks front and rear
NV4500 Dodge
Dana 300 Clocked with AA 32 spline output
Scout 33 gallon rear fuel tank.
4" BJ's lift kit and 33x12 R15 AT's
If you want to see how it was built or for any other pictures http://www.ifsja.org/forums/vb/showthread.php?p=840389
Read More | Digg It | Add to del.icio.us
More...
Cherokee S Chief WT
Currently:
NV4500 Dodge
More...
