4inch lift kit ?
4inch lift kit ?
Colby
NH
'05 Evo 8!, '75 CJ5,'00 Jeep Cherokee
I'm thinking of getting a 4inch suspension lift, the jeep already has a 3inch body lift when i got it.. I can't picture how big it'll be tho. anyone have the same set up i can see a picture of? or suggestions...
This is it now with the bodylift
IMO, I'd ditch the body lift and go with just the suspension lift. It will sit just a little higher than it does now, and probably ride much better (depending on the lift you end up with). If you aren't planning on big rubber, the two lifts combined will look like h*ll. If you are planning on swapping the rubber for bigger, start looking for bigger axles...
look at what offset your wheels are and how wide they are. You can help stop the tires from rubbing by increasing the offset and/or width of the wheels, and keep the wide tire look (if you want).
