69 cj5 spits and sputters in third gear
69 cjfun
I've got a 69 CJ5 . It's got the Dauntless Buick 225 V6 v6, and it absolutely falls on it face as soon as I try to accelerate in third gear. It runs perfectly at all rpm ranges in first and second gear as well as in neutral. Here's whats been done to it ...hei distributor conversion, heads had new seats and guides put in, I've run it with two different carbs and have the same issue with both.
So... what I'm thinking is that when I shift into third and change the load on the motor it loses vacuum causing the vacuum advance to fail causing a significant enough change in timing to cause it to run like it is out of time, popping and sputtering... push in the clutch it smoothes right out. down shift to second and it immeadiately recovers and roars to life.
Am I way off on my theory? Has anyone else run into this? How do I fix it?
Im going to recheck my vacuum lines, check for leaks in the carb and intake, but I've been anally thorough through my last inspections and found nothing. I'm going to add a vacuum canister to it to see if that helps.
