73 cj5 clutch disengagment issues.
wassmann113
hello, new here.
I've looked through various threads trying to find my issue that I'm having and I'm not having much luck.
the jeep has a AMC 258 i6 / 4.2l (AMC 258 i6 / 4.2l ) and a 3speed. I'm not sure if it origonal with the jeep itself or if it's a Frankenstein. the tub and title says it came with a AMC 258 i6 / 4.2l and then my core support says 304c.i.
however the issue I'm having is my clutch does not disengage. everything is lined up correctly and the clutch disk is in correctly.( stamp on clutch disk for flywheel side). I've tried the two options of clutches for my jeep, 3finger pressure plate and the diaphragm. I've tried both styles and brand new clutch linkage. new clutch fork.
the pedal adjustment is correct at about an inch of travel. however I don't have clutch disengagement while running. if the pedal is depressed and I start the engine in gear my jeep will slightly move foward. but it dosent go in or out of gear smoothly like before the job.
I'm at a loss here on what's going on and it's been very frustrating dropping the Transmission over again.
I believe it's a T-15 ? 3speed has Dana 300 Transfer Case .
some light on the situation would be appreciated. I'm lost haha..
