73 CJ5 spring bracket help?
Those look like sliding seat brackets. Shouldn't be too hard to come by.
This won't be too expensive Dear! That's what I keep saying. Over and over again.
Bestop does make them and should be at a local 4wd shop and also 4WD Hardware, or there is always the junk yard. If you do sit tall in the seat, there is always an option of bypassing the seat adjustment and bolting it into position.
FYI, only early 72 - 75 seat brackets will be a direct bolt on for your CJ. 76 and up brackets require extensive cutting and welding.
Those brackets are very rare, if you decide to use new ones PM me and I'll make an offer.
