Build Thread '74 CJ-5 Rebuild
DLane
Edmonton, AB
1974 CJ-5, Chevy 305 w/ Turbo 400 trans
You're on the way, I'll enjoy watching the progress.
Looks like you are off to a good start and have the room to play. Welcome from AZ!
Finally a build thread! Looks like great progress already! Man I would love to have a work shop; I'm on the driveway :(. Granted Kelowna isn't quite as cold as Edmonton :rolleyes: Keep at 'er, it's looking good.
Thanks guys. Was a long road to having this much room in my shop. Between my dad and my grandpa there was a lot of unneccessary junk but after a few weeks of cleaning and organizing I made a nice place to play for myself.
Coming along nicely! :D
Nice post.
Looks like the twin to mine! Good to see people renewing the older CJs!
Couple questions for ya.
Did someone lengthen the fender lines to install the Chevy engine? From the pic of the side view, it looks like they bondo'ed up the fender to body seam.
Did they do anything to the frame to fit the auto Transmission in there? Your driveshaft looks almost as long as mine, and I have a bunch more lift than you do. Generally, people say you can't fit an auto Transmission in a short CJ5 , yours proves that it can be done.
Last, do you only have 3 of the Swampers? lol I noticed the one wheel you showed cleaned up had an AT style tire on it (just messin' with ya here!)
Mylittlecj- I don't know alot about the swap as it was done by the owner previous to the last... And from what I can tell it wasn't done overly well. With the amount of rust and bondo on the fenders I can't say if they have been lengthened or not. Ill find out in a hurry when I get a new fibreglass set I'm sure! And not only is the auto Transmission longer, the adapter to fit the Transfer Case is probably 3" long as well. Ill do some measurements on driveshafts and compare some frames tonight. You've got me curious now haha.
And yeah only 2 swampers. Need to find 2 more. All tires are 33's but the AT's are worn down and measure 31.5 height and the swampers measure 33.5 and I'm worried about twisting a driveshaft or wrecking my Transfer Case with the difference in size.
Anyone have any thoughts on adding some color to my wheels? Would like to find simulated beadlocks or some trim rings or something just to add a touch of green to my wheels. Using original 15" wheels.
Yes, there are rock rims that weld inside the rim so the rim cannot be bent. They would add a nice accent.
BeadLocks & RockRings
Local company here in Kelowna makes some cool ones.
You could have a pin stripe added around your rim the same green, would be inexpensive and help break up all the black while matching the suspension...
PS it looks awesome, I am in the middle of rebuilding my CJ and have it tore down. Ready to take the body off, and tackle the frame and suspension.
