74 CJ5 Every steering component new: Squirelly above 25mph
ChesapeakeJeep
Yes, I had the alignment professional checked. Caster was 1 degree which was out of spec from 2 to 4 degrees but close.
Had a four inch Skyjacker lift but everything new from the steering wheel to the tires. I can show pictures. I bought it knowing I wanted to put in new tie rod ends, ball joints, but that ended with axles, spindles, steering box, steering shaft, bearings etc.
The two shops (one that did the work) and the one that checked the alignment are at a total loss.
So am I.
I mean it is bad. I don't expect great, but I drive all old trucks and this one is downright scary.
So am I.
