74 CJ5 spring plates
mriplaybass
Full Time Jeeper
Wisconsin
1979 CJ7 304 T18 w/6.32 lo d20 w/3.15 TeraLo D44 rear & D30 Front w/4.56 Eaton Elockers front and rear,
1959 CJ5,
1954 CJ3B,
1967 CJ5,
1947 IHC KB1,
1947 IHC KB2,
1947 IHC KS5,
1967 Mustang Coupe,
And let the questions begin! New to the Jeep world, and the forum, and boy, am I lost. We are building a................, well not realy sure what it is any more! Started with a 59 CJ5 and it now has a life of its own! 59 frame was in an accident, so we are using a 1960 frame. We want to put in a locker differential, so the axles are from a 74 CJ5 (Dana 44 & Dana 30 ) Does anyone know where to get a 74 spring plate? Planning on a 2 1/2 lift, probably Skyjacker. The 1960 axles are 2 1/2" diameter and the 74 is 2 3/4". Obviously, I can't use the 1960 plates. I can make my own, but my wife and I are planning to do the Colorado trip this summer, so time is a factor. Right now there is just a bare frame sitting in my shop, (oh yes, last night we discovered that it is bent! :eek:) so any parts that I can purchase will greatly expedite the build.
Thanks for the reply CJ. The plates under the spring with the shock bolt welded to it is what I am looking for. The link you sent is for everything 1971 and older. I have these from the original 1960 axles, and they won't fit. From 72 to 75, the Dana 44 was 2 3/4" diameter instead of the older D44s 2 1/2" diameter. And the 1960 D25s were 2 1/4" diameter with one of the "U" bolts going around the differential (not sure of the diameter of this "U" bolt, but bigger than 2 3/4") instead of the 1974 D30s 2 1/2" diameter. It seems as if 72 to 75 has fallen off the edge of the earth from all the big Jeep parts suppliers. At least as far as spring plates are concerned. I could probably use the spring plates for a pre 1972 Dana 44 (2 1/2") to fit the 1974 front Dana 30 (2 1/2"), but I am still at a loss for the 2 3/4" plates I need for the 1974 rear Dana 44 .
Too far gone. The plates themselves are not too bad, but the studs are only about 1/2 their original diameter from rust.
