Do it with greenbacks or do it with sweat equity, your pick.
[STEERING COLUMN]
Yep - get the parts from any intermediate GM column, you won't find them at a parts store - but any junk / scrap yard will easily hook you up. Jeep used a GM tilt steering column.
I used one from a 96 Cherokee in my 77. I had to get a creative with the u joint but is bolted on and plugged in.
A Cherokee (small) or Comanche column will pretty much slide right in. wire is pretty much plug and play. Trick is to find one with a key in it.
It is pretty much just a GM column but if you take one from a Cherokee it says Jeep on the wheel.
Read more:
http://www.jeep-cj.com/forums/f19/need-steering-column-21968/#ixzz2ycGud2AQ
I pulled the column from a 87 GMC 1/2 ton, swapped the lower steering shaft from the Jeep column into it, I think it cost me a total of $60.00.
The bonus is it moves the dimmer switch from the floor to the column.
Read more:
http://www.jeep-cj.com/forums/f19/need-steering-column-21968/#ixzz2yllzs99W
GM columns were used starting in 76 and are a common swap for 72-75s.
Read more:
http://www.jeep-cj.com/forums/f19/steering-column-identification-19113/#ixzz2WQvqSUot
As IO said, Cherocar's are good, you even get a Jeep logo'd steering wheel. Late 80's early 90's Firebirds work well too.
I believe the year would be 73- 80's for the steering columns.Look at a Chevy Truck of that year same column.
A 92, 93 chevy blazer column will bolt right up. In fact the adapter for the steering wheel is the same as the cj.
Read more:
http://www.jeep-cj.com/forums/f19/tilt-steering-17483/#ixzz2Luiat8dW
I just did this exact replacement today, the steering shaft will collapse if your in a accident, mine had 2 plastic pins keeping it from moving. but i have seen some that will slide. Mine is a 1985
CJ7 . What i had to do was loosen the 4 bolts that hold the steering column in the dash and slightly putt the steering wheel up and into the passenger compartment. Not it only needs to move about an 1 1/2 and it will easily come off of the steering column. once you get to the point, remove the clip, then the cover and pop the bearing out and then the plastic retainer. Then put in the new plastic retainer and then the bearing (make sure to lube it) and then the retainer cup and then the clip. Then push the steering wheel back into the dash and on to the shaft and put back the bolt to hold the clamp and your good to go. Hope this helps.
Read more:
http://www.jeep-cj.com/forums/f19/upper-steering-bearing-6454/#ixzz2WQwloe3w
I disassembled the steering shaft in my Son's '80
CJ7 and replaced the upper bearing. When I began reassembly, the splined shaft coming out of the firewall only penetrates the coupler about a half inch. I noticed the shaft is notched to accept the pinch bolt. Does this shaft have a slip joint also? Help!
Read more:
http://www.jeep-cj.com/forums/f19/upper-steering-bearing-6454/#ixzz2WQxJJ2vm
Yes it does. It will move in and out inside the column. Just get ahold to it and give it a good yank!
Read more:
http://www.jeep-cj.com/forums/f19/upper-steering-bearing-6454/#ixzz2WQxNNs00
75 is a different animal than a 77. The floor is shaped differently and thus the pedals are all shorter than the 76+ ones.
Most folks swap to the pedal assembly from a 76+ CJ or YJ in order to use a GM column, which is essentially what an XJ column is.
You'll have to shorten those 76+ pedals, some holes won't line up, you need to cut a bigger hole in the dash, and the downstream steering linkage won't just bolt up.
I'd suggest trying to get everything - from steering box to the horn button - from the same donor CJ to make this mo' easy on yourself if at all possible.
earlycj5.net has a dedicated 72-75
CJ5 forum that is probably the best source of info for your Jeep. Old threads there will cover this swap in great detail so go check it out. Not knocking this forum but most folks here only speak 76 and up, and assume CJs are all like theirs, and will unintentionally steer you the wrong way sometimes. 72-75 intermediates are the real b@st@rd children of the CJs.
Another option is shortening your bus column or changing the angle, if you want to keep that old school vibe. That's way easier than swapping because that column is so darn simple inside it. You can get repro wheels and upper bearings, and Advance Adapters makes the unobtainium lower bearings for $25 or so, so it is possible to get it back to like new condition.
Read more:
http://www.jeep-cj.com/forums/f19/retrofit-steering-column-19897/#ixzz2cqiVmGxQ
__________________
