Steering 74 cj5 steering column
Tommydp
California
74 cj5
I recently acquired a 74cj5 and where the steering column passes through firewall it has a lot of slop, as if there is a missing bearing or bushing. Looking for advice/ info on how to approach and if there are parts available to fix.
:welcome: If it has a stock column (just a round tube) the should be a bearing at the bottom of the tube that centers the steering shaft and does not allow slop. Some later 74's have a GM type column. Can you take a pic of the column with the wheel and one inside the engine bay at the firewall?
Any idea where I would find that bearing or locate a part number/ schematic that shows part. I can find parts from 71’ and older and 76’ and newer but having difficulty finding parts for 72’- 75’.
You do not need to post interior pics. That is a stock 74 column. I have a 72 and it's the same.
I'll get you rebuild kit numbers as well as other info when I get home I'm on my phone right now having some wings and a :beer:.
Gotta have priorities... :chug:
$120.00
  60.0%
