75 CJ5 Dana 30 Camber Specifications?
sorry didnt know about that...specs in nowUsually you want 3 to 4 degrees positive Camber. Can you fill out you jeep specs?
Most everything feels tight except the right wheel bearing is just a little loose.Looking from the front,wheels leaned in - camber, leaned out + camber I've seen at least 3 different measurements ranging from -.25 to 0 degrees. so I guess straight up would do. Question ... Have you checked your ball joints and wheel bearing adjustment? These pieces out of adjustment would represent as an out of camber situation. If they are good and your axle is bent its not over yet it can be straightened but it's a bit costly a cheaper alternative are camber shims from Ingalls eng. p/n 26126 application is for the Dana 30 and come in different degrees. They go between the spindle and outer c .
Hi all- I looked around on the web for camber specs. My old CJ5 is at .5 to 1 degree positive.The only thing I could find was on a Jeep tech site and they say 0 degrees so straight up and down... are you folks okay with that?
