75 cj5 wiring harness replacement
wardly258
I have started on the great journey of replacing my wiring harness today and would like to show some pics as well as get any advice possible from some one that has done this before. One of my main problems is the turn signal wiring. The steering column has 10 wires coming out of it to a connector (tilt column) Im trying to figure out what goes where but tracing wires through the old harness is impossible due to splices, tape, wire nuts, ect. everywhere from the PO. Ive tried going at it with a meter and seeing where i get current from but its not making sence to me cause nothing really changes between the pins when i flip the switch. Yes the turn signal switch "worked" before i pulled the rabbits nest out from behind the dash so i no the switch works. Any help would be perfect drawings would be greatly appreciated and this is a universal wiring harness. Thanks in advance!!
