78 cj 5 shackels
78 cj 5 shackels
oldcj
rohnert park ca
78 jeep cj 5
hi im looking at installing 2 inch shackels lift on my CJ5 is this a bad thing to do or are they safe to run wood i need to do any more work on it to make it drive right . or can i just run it the way it is . thanks if you can give me any info that wood be nice:)
Two inch shackle extension equals a one inch suspension lift. This will affect your steering castor and could possibly effect your steering.
Why just a one inch lift? What are your trying to accomplish?
more room for my tires . i will just get a new lift kit and not do the shackels its not worth doing that small lift any way . thank you for the info :)
Like Cj said shackle lifts can really mess with your handling. If its tire clearance your looking for and dont mind cutting the body a little Tj flares work good.
What size tires do you want to run?
I do not like shackles for reasons above. I cheap and easy way to gain a couple of ins is a add-a-leaf.
