'79 CJ5 Front Shock Mount Locations?
CJ5Driver
- Dallas Texas
- 1979 CJ5 Bordeaux Metallic Paint Code 9P
350 SBC Conversion Replacing 258
D30, T150, AMC20
I recently converted (or am in the process of converting) my '79 CJ5 back to the original stock suspension. The PO had installed 33" tires and heavy duty springs with Monroe Magnum shocks. Made for a pretty stiff ride with the tires taking most of the abuse. My question is why are my front shocks compressed as much as they are and shouldn't they be mounted in front of the front axel? Do I need to move the upper shock mount further forward into the open hole in the wheel well and reverse the spring plate (L & R) so the shocks mount in front? Also, any idea why there are six holes drilled into the frame just aft of the upper shock mount?
