79 cj5 Tub removal
Hangin
I am hoping that this post keeps at least one person from feeling as stupid as I did last night.
I was in the process of removing the tub on a 1979 CJ5 and learned a few valuable lessons the hard way.
1. Using a sawsall on rusted body mounts is a PITA. That rubber is like glue. Instead just use a grinder and take the bolt head off
2. Lifting from the rollbar is not the best place to lift from.
3. The one that made me feel the dumbest was after trying and trying to get the steering shaft to disconnect at the knuckle in front of the firewall. What I did was loosen the bolt and pb blasted it for a couple of days, it was loose but just wouldnt come apart. I tried everything except one. Yup you guessed it, take the bolt all the way out dummy. The shaft is grooved, live and learn
