Build Thread 79 V8 CJ7 rebuild
wondernad
- Raleigh, NC
- 79 CJ7 304, 98 XJ 4.0l, 90 YJ 2.5, and 93 240sx sr20det
So, I have been mulling it over for quite some time now and have decided its time for a rebuild. The cancer has started spreading rapidly and needs to be fixed before it is no longer saveable. Unfortunately due to family and budget restraints the build process will be going along at a snails pace. But since its been sitting for a while and no sign of actually being driven in any near future now is as good a time as any. And since teardown wont cost a dime I can get started on that.
I originally started by trying to rebuild the carb to get it running again. So the carb was off and I needed to drain the tank due to bad fuel. Well the fuel had disintegrated the fuel sender float and tank filter causing the lines to clog while draining with an electric fuel pump. So I dropped the tank and noticed the frame rust to the passenger side frame rail. So on for the debate of what to do. Body off or try to bandaid the current issues and wait for new ones to arise. Well I don't like option 2 so body off is the way I am going.
Start with some pre-teardown pictures of the rust and PO's riggings. Hope to start the body removal soon as the weather is improving quickly.
More Pictures
CJ7 pictures by wondernad - Photobucket
More Pictures
