82 CJ8 Fuel Filler Neck
Scrambler jim
Ocala fl
82 CJ8
Are there different part versions for the fuel filler neck on an 82 scrambler. I just installed complete 15 gallon tank setup with new neck, vent and filler hoses, tank, skid plate, strap kit, sending unit etc. The hoses are for the 15 gallon tank and dont reach the new Omix fuel filler neck. The neck has tubes about one inch long. My Jeep that I just purchased has a 20+ gallon plastic tank kit that had a bad leak, so I changed everything out to stock setup. The fuel filler neck that was on the jeep has tubes that are between 6-7 inches long. The new 15 gallon tank hoses match to the old neck.
My question is I don't see a part number for a neck with tubes that long. Whyc doesn't a new fuel filler neck work with all new parts for 15 gallon tank? I'd use the old filler neck but it has been banged up a bit and I would like new. Any help would be greatly appreciated. Jim
No difference in part number for fuel filler neck 82/83 Scrambler.
Same neck used for both 15/20 gallon tanks as well.
Now for the filler hoses, part numbers all over the place.
81/82 with 15 gal tank: 5362773
82 with 20 gal tank : 5363317
83 with 15 gal tank : 5364196
83 with 20 gal tank : 5364198
Without all of them laid out side by side to compare, who knows.
