83 cj5 Ignition push rod?
opie
- Nevada
- 1983 Cj 5
Inline 6 cyl. 5-speed manual trans.
Original everything. 2nd owner.
9,000 miles. (really) Had 4,000 when I bought 8 years ago. Drive on weekends in local desert.
Kids getting anxious to drive it.
I am having problems with my ignition switch. Or so I thought. I pulled the steering wheel and replaced the ignition key switch. It was still tough to rotate and then would just easily flip back and forth without turning power on or turning over. After looking into the column I realized the little push rod with the gear teeth, that gets pushed back and forth inside the steering column, has broken in half. so I have about 5 inches of the slotted rod pulled out and it appears to have snapped in two. So the rod inside the column is not engaging with what it needs to. Basically I need to replace that rod. It appears I will have to take the entire column apart. I am not familiar with it, nor do I know where to begin to look for this piece(what is it even called) or how to pull it and put back together. Thoughts? Better left to a pro?! Any advice or help would be greatly appreciated. Thanks
