'84 CJ7 front caliper question
- Mt. Cheaha, AL
- '84 CJ7, 258, T4, D300, D30, AMC20, 3.54 gears
Hello everyone, new jeep owner. I've wanted a CJ7 since my teens, life has finally reached the point where an impractical vehicle makes sense.
So I'm going through the brakes and the front caliper seems odd, as in they may not be the correct calipers. The front ears that i would think keep it in the bracket don't appear to be long enough. The rear tab is seated under the bracket.
Do these look correct? pics attached
Caliper also seems to hang downward at an angle to the point where it rubbed the outer edge of the disc, partially due to the wheel bearing slop.
Also what is the torx drive for the guide pins, had a T40 (too small) and T55(too big)
While I have it up in the air the DS bearing has some play in it, going to check the bearing preload and IIRC it's a 2-1/16" correct?
