84 cj7 steering won't return to center
b3uhbp
- Arlington, TX
- 84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
A little background. I've had this jeep for a year. 2.5" Rancho springs and slightly longer shackles with 32/11.50s, very modest lift. Drove pretty good, no death wobble etc. but had a little slop and drift in the steering so I checked tie rod ends, ball joints and wheel bearings, all checked out okay. I replaced bushings for sway bar, end links and springs which really tightened up the steering. Everything was good except the wheel wouldn't return to center, so I checked the caster and it was 4* positive so I added 2* steel shims but didn't seem to make any difference. Have not checked the alignment yet. So here is the question. Should an 84 CJ7 steering wheel return to center after a turn or is this just a pipe dream? I've read and learned a lot from this forum. What am I missing?
