Misc. 85 CJ change master brake cylinder
sledfisher
thanks for the add, looking for a part number for a brake master cylinder, that has the bleed nipple to use a pressurized bleed can to bleed the brakes. if i add power brakes that master cylinder has a nipple to use the pressure can.85CJs normal brake cylinders do not have the nipple nor can you add it .anybody change thier master brake cylinder
