Misc. 85 CJ change master brake cylinder
sledfisher
Washington, USA
1985 cj7
thanks for the add, looking for a part number for a brake master cylinder, that has the bleed nipple to use a pressurized bleed can to bleed the brakes. if i add power brakes that master cylinder has a nipple to use the pressure can.85CJs normal brake cylinders do not have the nipple nor can you add it .anybody change thier master brake cylinder
In my '84 when I converted to power brakes, I installed a SW Performance Parts #MC1321H master cylinder and their #PB8531 booster. Very pleased with the pair. I've never seen in person a MC with a built in pressure nipple to bleed the system with. I've used the pressure systems that replace the MC cap with a temporary nipple you connect a pressure can to. These are quite common.
I did find this one that looks just like the one I used, except it has the bleeders on it. eBay Link
But these nipples are bleeders (like on wheel cylinders/calipers) not a place to insert pressure like I interpret your question to mean.
