85 CJ7 with 2" lift power steering shaft too short
LaraFaye1
Tarpon Springs, Fl
1985 CJ7
Just lifted the body 2" and now the power steering shaft does fit right into the coupler. Going on a trip tomorrow and hoping for an idea to correct it
There are 2 plastic pins in the shaft. If you drill (or melt) them out, then you will be able to extend the shaft some.
Have you already addressed the clutch linkage, Transmission shifter, and Transfer Case shifter?
Don't forget the radiator's position, and fuel tank filler lines either.
Take a torch to the shaftnto melt the plastic and stretch it out. Please wear a respirator or do it outside.
