86' CJ-7 Laredo Suspension Lift Questions: Need Advice
OneBadMudder
Okay, so I'm trying to get a little bit of advice before I start trying to install a 4" BDS suspension lift on my 86' CJ7 . First of all, it has a Dana 30 front, Dana 44 rear 2.73 gear ratio (getting that changed to 4.10), Dana 300 TC.
I want to make sure that the driveline is angled properly, but am not too sure about how to accomplish this. I know that I can order a tom woods cv driveshaft, and will probably need to have the spring plates re-positioned on the axle tubes.
Will I need to get a SYE like i did on my Jeep TJ? What is the procedure for lining up the pinion angle / re-positioning the spring plates? I'm sure this stuff is covered somewhere on this site. Anyone know of any good threads that have a detailed install? Thanks in advance for your input!
