87 YJ problems
cdlongjr
- Media
- 14
- Newark, De
- 1983 Jeep CJ-5, 1987 Wrangler YJ, 1974 J-10
Drove Mama's YJ for the 1st time yesterday. She has several problems. YJ is lifted, but I don't know or know how to tell how much lift was installed. Frame is 25" off the ground @ the front bumper & she has 32" tires. I have changed out the Weber for an MC 2100.
Engine has a bad miss, but I don't know if it's electrical or vacuum. The YJ has a TH-350 auto. The modulator vacuum line is tied into the vacuum advance for the distributor.
Horn doesn't work, but did blow several times yesterday when I was turning while backing out of the driveway. When turning the steering column has 1 spot where a grinding/ clunking noise is heard.
The power steering seems to have hard & soft spots when turning.
Heater also has problems. Temp cable doesn't move & I can barely move the control lever on the heater by hand. Won't change from heat to defrost. The cable moves, but nothing happens. I see there are vacuum ports on the heater controls. Where does the vacuum come from. I think no vacuum to the controls is part of my problem as no vacuum lines come thru the firewall that I can find. The fresh air, (vent), doesn't work either. I can move the door by hand.
Need ideas where to look for causes to these problems.
