A Little Courtesy on the Trails Please
BusaDave9
Always Off-Roading Jeeper
- Featured
- 3
- Media
- 361
- Resources
- 2
- Durango, Crawlarado
- 1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
The last time I was driving a Jeep on the mountain trails (it was a rental - don't ask) I came across a virtual traffic jam in the wilderness. Someone had trouble with his jeep. He was in a big group (all out of state) and his buddies pulled up along side of him and they blocked the whole trail for over half an hour. Jeeps and quads coming from both directions were backed up. It was no use asking them to move to the side, they were almost done. Just sit tight a few more minutes. When they were ready to go they looked around and saw jeeps in both directions so they yelled out "Can you guys backup and find a place to pull over?". Slowly things got moving.
This was on the "Alpine Loop" between Silverton and Lake City Colorado. Here in Colorado some trails get very busy in the tourist season. There are also some very narrow trails where passing is possible only in a few places (but the above mentioned trail was big enough for at least 2 jeeps and they still had it blocked)
There are a few rules that would be nice if people would follow this common courtesy.
1. Be considerate. Don't block others unless it is unavoidable.
2. If you can't make it up an obstacle after 3 tries pull aside and let others pass.
3. If a trail is marked for 35 inch tires, 2 lockers and a winch. You can try it with less but if there are others behind you be quick to pull aside.
4. On the street you keep right but on the trails you should drive and pass on the left. The reason I say that is here in Colorado some trails have some very dangerous drop offs. If you pass on the left both drivers get a good view of the edge of the trail. I would rather run into another jeep than fall off one of the shelf roads around here.
5. Most people say the jeep that is going up always has the right of way. I disagree, I think rule 1 supersedes all other rules. There are times it is easier for the person going up to pull over. Think about what would be easiest for everyone, not just yourself. For example if I am going up a narrow trail and there is a large group coming down. It is best for me to take the one pull out space. If I were to make one of them pull over, what would I do next? Have everyone else back up to the top?
What does everyone think about these? I know a couple of these are against the norm so feel free to disagree if thats what you think.
